No brake lights but all other lights work
Discussion in 'Mack Forum' started by bigmackva, Sep 24, 2024.
  1. bigmackva
    bigmackva Bobtail Member
    I have a 2003 MACK CH600/613. When pre-tripping my truck this morning, I noticed the brake lights would not work at all, even when pulling down the Johnny-Bar. All fuses are good. Has anyone ever ran into this? Do you know where the brake light switch is located? I know there are 3 switches above the brake pedal and accelerator pedal but I don't think those are the brake light switch. Any help would be appreciated.
    Also-the hazard, turn signal and running lights al work as designed.
  3. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,144
    Apr 1, 2011
    Broomfield, CO
    Haven’t worked in a CH in forever. so I could be way off or it may not be an exclusive layout, but I believe those had them attached directly to the treadle valve. If they are, it’ll be a disc shaped dingus with two wires secured to it.
    Also, try swapping your brake lamp relay for a matching relay and see if that changes anything.
    And remember, science has not discovered a cure for disco fever.
