No crank no start on a Int'l 4300
Discussion in 'International Forum' started by Robbie Walls, Jan 8, 2021.
  1. Robbie Walls
    Robbie Walls Bobtail Member
    I have a 2002 Int'l 4300 with an Allison Automatic It will not crank when you turn the key it has no park indicator and it says check electrical system I think it's not cranking because the truck doesn't recognize that it's in park Has anybody run across this problem I've changed the neutral safety switch and I've changed the TCM
  3. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    The transmission is not being detected on the datalink. Check the main trans fuses at the battery box. If they are good, you might have a datalink problem.
  4. Robbie Walls
    Thanks all the fuses are good and I replaced the trans computer and the wiring harness looks good and I checked the shifter and I've had about five people look at it and nobody can figure it at I'm about ready to hunk the truck
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,518
    6,578
    Aug 26, 2014
    Have seen problems with connectors on smaller wires from the batteries on a similar truck. Positive and negative. Finally cut all of them out, soldered and sealed them.
    Testing is recommended to swapping parts.
    Had another one with a bad switch in the parking brake handle assy.
    Another had the transmission wiring to close to the exhaust. Internal meltdown but the outside looked good.
  6. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    Like HeavyD said check those powers and grounds thoroughly from the battery box to the TCM. Also remove the connector at the TCM and check for powers and grounds, load test with headlight if need be.
