No drain plug
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JonJon78, Oct 9, 2021.
  1. JonJon78
    JonJon78 Road Train Member
    7,212
    42,348
    Jul 1, 2018
    What is the reason for making differentials with no drain plugs on the bottom?
    Dave_in_AZ, 4mer trucker and cke Thank this.
  3. cke
    cke Road Train Member
    6,057
    74,630
    Aug 4, 2013
    Colfax Wi
    Probably same reason they don’t put grease zerks in u joints anymore. Maintenance free.
  4. Goodysnap
    Goodysnap Road Train Member
    3,746
    9,108
    Jul 12, 2017
    Fluid probably drains thru a differential pattern mount bolt. What are we working on- Diff, Model , photo?
  5. AModelCat
    161,376
    Probably located on the center section, rather than the housing. As mentioned above it might be one of the lower bolts.
    Rideandrepair, A5¢, JonJon78 and 2 others Thank this.
  6. Cattleman84
    Cattleman84 Road Train Member
    9,995
    71,324
    Nov 1, 2017
    The Sticks, Idaho
    If it's fairly new it could possibly be to force most folk to take it to a dealer to be serviced. The majority of folks dont know how, or simply dont want, to split a diff and get it back together without leaks.
    Rideandrepair and JonJon78 Thank this.
  7. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    The lower bolt when it falls out will drain most of the gear oil out but it will leave a space for dirty lube to sit in the very bottom of it?
  8. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    Built to fail technology. The manufacturers have testing lab for the parts. They have calculated the amount of time parts last and compared it to the bottom line profits on getting more money out of you by either buying a new truck or replacing the part.
    It's a business model that runs with the statistical risk of having a recall or a lawsuit vs boosting the corporate profits. They lessen the quality just enough to keep you coming back without getting in trouble
  9. Heavyd
    Heavyd Road Train Member
    7,808
    6,258
    Feb 4, 2009
    It always comes down to money. They save $20 per truck because the machining and plug for each axle is another manufacturing step they can skip.
  10. JonJon78
    7,212
    42,348
    Jul 1, 2018
    Spicer. The previous truck I owned didn't have one either, they had to stick a hose down in the fill plug hole and vacuum the old oil out... One would think with how much money they charge for these fancy Peterbilt 389s they wouldn't be cutting corners on something that cost so little to do from the factory...
    Pictures aren't great but here's a couple, I looked at it again this morning and there's no bolt or anything at all on the bottom.
    Rideandrepair, D.Tibbitt and Oxbow Thank this.
  11. AModelCat
    161,376
    What about the bottom-most bolt holding the carrier into the housing? The bolts either side of it have grade markings cast into the head, that one looks blank. Wonder if that bolt is intended to double as your drain plug?
