I got Freightliner Century 2007 Detroit, my cruise control and engine brake are not working, I replaced clutch switch and speed sensor from the other truck that doesn't have any problem with these things and it didn't work. My cruise control is working only when idling , also-when idling nothing happens when i press clutch or brake pedal, rpms go down only when i release parking brake.
No engine brake and cruise control.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Ker, Mar 11, 2018.
Page 1 of 3
Check brake pedal switch and/or accelerator pedal position switch.
fss99701 Thanks this. -
I'll do that,thank you.
Are they located on pedals , (same as clutch switch) ?
Also check that the clutch pedal return spring is not broken, when it's broken, your clutch pedal doesn't go back up all the way, so it will keep the cruise control from working.QuietStorm Thanks this. -
could be the relay my freightliner the relay went bad took out the cruz and jake
Problem solved . I feel embarrassed to say what it was . Clutch switch jack that connects with the cable which is going from computer was disconnected.
Big_Z, fss99701, ShooterK2 and 1 other person Thank this. -
There's no need to feel embarrassed, sometimes if you don't ask a question, you won't get the answers and the motivation to look for or fix the problem.JoeyJunk, fss99701 and Justrucking2 Thank this. -
JoeyJunk, HopeOverMope and Justrucking2 Thank this.
Thank you for giving away your knowledge and time.
Page 1 of 3
