NO Ground 27 MHz antenna
Discussion in 'CB Radio Forum' started by russbrill, Apr 28, 2020.
  1. russbrill
    russbrill Medium Load Member
    325
    226
    Nov 10, 2017
    Firestik ® II
    "No-Ground Plane", CB Antenna Kit
    With stainless steel 3-Way Mount
    Model: FG2-648-? w/2ft antenna $68.99 (MSRP*)
    Model: FG3-648-? w/3ft antenna $70.99 (MSRP*)
    Model: FG4-648-? w/4ft antenna $72.99 (MSRP*)
    *MSRP (Manufactures Suggested Retail Price) in U.S. Dollars
    Whereas "?" designates antenna color; B=Black; R=Red; W=White; BB=Blue;.
    You can view this product and other Firestik products at Firestik Antenna Company Home Page ..
  3. russbrill
    325
    226
    Nov 10, 2017
    I posted this thread for the Guys/Gals that need to do a quick 27 MHz install in their trucks.. If anyone is currently using this product, please provide some feedback for other users of the CB Forum.
  4. BigJim63
    BigJim63 Light Load Member
    61
    60
    May 1, 2014
    Evansville In.
    I have read on other forums that this doesn't work very well.
  5. russbrill
    325
    226
    Nov 10, 2017
    I imagine it's a compromise design that focuses more being a 50 Ohm match, than on being an efficient radiator...
  6. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    I believe coax length is important to the tuning of this design as this coax type serves as the ground plane / counterpoise / second half of the antenna / whateveryawannacallit.
    I've been told that this design achieves about 70% of the range of a standard ground-based antennas of the same length
  7. Ridgeline
    22,636
    120,583
    Well a few thoughts
    First is there is no such thing as counterpoise in mobile applications
    Sorry it is true, because it is applied to fixed station antenna systems only.
    Second these antennas are common mode current antennas. They tuned the coax to act as part of the unbalanced system and gives a false swr.
    Does it work?
    Sort of but very ineffective antenna.
  8. trees
    trees Road Train Member
    1,061
    833
    Jun 29, 2010
    It's been awhile since I've studied this stuff...
    But, I believe the counterpoise is simply the reflective element. Whether it's a ground plane, earth gtound, or ground half of a dipole... the counterpoise is what the driven element reflects against. In order for the antenna waveform to generate and develop a field it needs something to act like the phantom half, or negative image...
    Antenna efficiency is dependent on the conductivity of both the driven element and ground image element, as well as the radiation resistance of the feedpoint and how closely the impedances match between the antenna, feedline, and signal source, I think.
    SWR is nothing more than the ratio between the impedance of the radio, and the load, the load being the antenna....
    If the coax shield is used as the counterpoise then it's length is critical because it's acting as half of the antenna. It's undesirable to do this because the RF traveling on the ground braid is coming back to the radio.
    Where am I going wrong?
  9. Meteorgray
    754
    597
    Jan 1, 2016
    Yeah, ole Ridgeline is a stickler for using the precise definition of such terms as "counterpoise." Such terms and their definitions probably originated for base station operations, and they don't transfer exactly as conceptualized to mobile applications, although they are quite functionally similar in how the antenna works.
    It's kind of like those folks who go nuts when somebody spells "Cummins" with an extra "g" at the end. It's not important in the grand scheme of things, but it ain't perfect in application.
  10. Ridgeline
    22,636
    120,583
    Yes I like proper terms.
    trees, please learn how balanced systems work, it will explain how the rf signal is transmitted.
  11. trees
    1,061
    833
    Jun 29, 2010
    I believe a balanced system is one where the driven element and the reflective element are the same physical length. A balanced system is symmetrical at the feed point.
