No heat on 2010 T660 with cummins
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Richter, Jul 5, 2014.
  1. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Hi Guys,
    A/c was working really poor before it was fixed, so Im guessing someone closed off the heater core valves to make it work better. Right now the truck has no heat. Any one know where those valves are? Any other reason you can think of that the heat wont work? Its 45 outside now lol.
    Thanks
  3. Duramaxxed
    Duramaxxed Light Load Member
    155
    60
    Jan 2, 2012
    Bourbonnais, IL
    Right side of the engine. Towards the rear if it is a cummins or a paccar. Right side front if it is a cat.
    Richter Thanks this.
  4. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Are they big yellow valves? I thought those were for the apu....the big yellow ones are open.
  5. Duramaxxed
    155
    60
    Jan 2, 2012
    Bourbonnais, IL
    What engine?
  6. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    cummins (in title lol) 2010 truck but engines is 2007 emission
  7. Duramaxxed
    155
    60
    Jan 2, 2012
    Bourbonnais, IL
    Yeah, 2 valves directly behind the exhaust manifold. If they are 1\4 turn valves the bar has to be in line with the flow of coolant. If you still have no heat one of your mode actuators on the hvac unit is stuck.
  8. Ridgeline
    22,519
    118,855
    You should have two valves, one in the back near the top of the engine and one near the front near the frame rail - the front one will be behind the water pump. You can follow the heater hose to find them.
  9. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    thanks guys, those are both open, i guess i got a bigger problem with my hvac system
  10. Ridgeline
    22,519
    118,855
    Are you sure?
    Check the control valve which is located near the heater core itself, it should be open too. There is no reason why you should not feel the hoses get warm when those valves are open, I burned my hand one of them on a truck when I was trying to figure out if they were open or closed.
  11. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,144
    Apr 1, 2011
    Broomfield, CO
    Right side of the truck, behind the HVAC filter, you'll see some coolant lines running into a device.. black plastic casing with one line running up into the dash, and a curved copper line at the bottom which connects to another coolant line... there'll be an electrical connection into it, as well.. that's your heater control valve, and it's not so uncommon for those to go out.
