No hole for tach sensor after trans swap
Discussion in 'Peterbilt Forum' started by TWC, Jan 28, 2016.
  1. TWC
    TWC Bobtail Member
    15
    Mar 18, 2014
    I just got a 1997 379 with an n14. Previous owner swapped out a broke 18 speed for an older 15 speed with lo-lo. I noticed the tach wasn't working and found no sensor on bellhousing nor a hole for it. What can I do to have a functional tach again?
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Look all around for the hole it may be on side or top, if its so old of a trans that it did not have the hole you can drill one an install the old one out old trans?
  4. TWC
    TWC Bobtail Member
    15
    Mar 18, 2014
    I will look on the side in the morning. I can drill and tap a hole. That's not a problem. Just not sure where exactly to put it.
    Thanks
    baha Thanks this.
  5. AModelCat
    159,671
    Shouldn't the speed sensor for the tach be in the engine flywheel housing, not the transmission bell housing?
    wadamc, GrapeApe and wore out Thank this.
  6. TWC
    TWC Bobtail Member
    15
    Mar 18, 2014
    Is it on the block? I thought it was on the bellhousing?
  7. wore out
    wore out Numbered Classic
    16,042
    194,297
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    No northern mechanic is ridgt if they just swapped out the trans then tach pick up shouldn't be affected. It reads off the flywheel teeth.
  8. TWC
    TWC Bobtail Member
    15
    Mar 18, 2014
    Okay I'm about to go out there and do some work on the truck anyway so I'm going to look it over a real good again and check
  9. wore out
    16,042
    194,297
    Jun 5, 2013
    Sometimes there is a plastic plug screwed in the hole
    AModelCat Thanks this.
  10. TWC
    TWC Bobtail Member
    15
    Mar 18, 2014
    Would it be at the bottom? There are two large threaded holes at the bottom, one straight down and one off to the passenger side at an angle? These are both about the same size as the speedo sensor on the rear transmission
  11. wore out
    16,042
    194,297
    Jun 5, 2013
    The one off to passenger side
    wadamc and AModelCat Thank this.
