no idle, battery cuts power, freezing
Discussion in 'Questions From New Drivers' started by ShadyJ, Nov 6, 2013.
  1. ShadyJ
    ShadyJ Bobtail Member
    10
    8
    Nov 3, 2013
    alright guys, I'm a little worried about going to sleep and not waking up due to truck power shutting off the Webasto heater. Woke up today freezing.
    Also truck will only idle 5 minutes max.
    Any advice?
    HappyHardCore Thanks this.
  3. 123456
    123456 Road Train Member
    10,555
    5,747
    Oct 22, 2010
    32179
    what fine outfit is this ?
    GITRDUN45 Thanks this.
  4. rockee
    rockee Road Train Member
    1,393
    673
    Apr 17, 2007
    Pacific Northwest
    Long Johns
    123456 Thanks this.
  5. GITRDUN45
    GITRDUN45 Heavy Load Member
    712
    236
    Sep 30, 2013
    What company you drive for?
  6. jormm14
    jormm14 Bobtail Member
    28
    Nov 2, 2013
    Run teams... Consider the little spoon :biggrin_2556:
  7. DrivingForceBehindYou
    DrivingForceBehindYou Medium Load Member
    546
    184
    Aug 29, 2012
    ChicagolandOfOpportunity
    Id refuse to drive till the problem is fixed. I am sure it qualifies as unsafe working conditions. Use Qualcom or text messaging to report and request the repairs. Probably just needs new batteries.If they fire you should be an easy win for you.
    Are you saying if you apply trailer brakes only it will still shut down?
  8. GITRDUN45
    712
    236
    Sep 30, 2013
    I'd bet this driver works for large outfit (swifty,jb ,Schneider etc...) and it has auto shut off to stop idling.
  9. ShadyJ
    10
    8
    Nov 3, 2013
    Yep, auto shutoff every 5 minutes, you won! I work for The Mega (as of this writing, that is, that all could change is an hour).
  10. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    Many of these companies have it set that if you are waiting for a train with your foot on the brake even, it will shut off at 4 minutes.
  11. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    Schneider does that. Their idle timer isn't bypassed by the truck having the parking brake released, which to me is madness.
    My company has idle timers, but they are defeated and the engine will run until the fuel runs dry by either bumping the cruise to activate the PTO setting (Volvo and Detroit engines) or feathering the throttle when the idle shutdown warning pops up on the vehicle message center (Cummins ISX).
    Our policy on idling is simply minimizing it whenever possible. Don't leave the engine running if you are inside the truckstop watching TV in the lounge or taking a shower. The Teletracs message/GPS unit will automatically send a message about idling but that's only if the system shows that the truck has idled more than 10 hours in one shot or your fuel economy drops below 6.5 mpg. No penalty, no lecture, just a friendly reminder to minimize idling.
