No marker lights when headlights are on
Discussion in 'Freightliner Forum' started by nternes, Feb 19, 2013.
  1. nternes
    nternes Bobtail Member
    I have an 03 Freightliner Columbia. When the running lights are on all marker lights on the trailer and truck and top lights on the truck are on but when the headlights are on, the top lights are not and only the front marker on the trailer comes on. Replaced the 3 pos switch, did not fix it. Any ideas?
  3. batch
    batch Bobtail Member
    did you figure it out i have the same problem????
  4. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    See if one of the circuit breakers for the trl taillights or marker lights is popping.
  5. eeb
    731
    268
    Mar 24, 2013
    Might be a faulty circuit breaker, kinda weird, now I'm intrigued.
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    may be bad grounding
  7. mgrantes
    mgrantes Light Load Member
    111
    30
    I just bought an '06 Columbia and first day out (while driving at night in the rain) I learned of this similar issue. Currently having the dealer look into it. But basically, if my headlights are on then my interior dash as well as trailer lights turn off. But if I flip the switch down to the marker position everything comes on except the headlights. ...weird. Hopefully a simple fix. The windshield also leaks pretty bad which may be the culprit. I'll know within a day or two. Interested to see how the OP's situation develops.
    Hemingway22 Thanks this.
  8. yetti028
    yetti028 Bobtail Member
    7
    Any update on this, I just started having the same problem.
  9. mgrantes
    111
    30
    For me, at least, it turned out to be a short in my left side marker. Pretty much all the electrical to my rear was routed through that same wire bundle. I have no idea how that affected my dash but since i replaced that socket and bulb a few weeks ago I haven't had any problems. If it does come back then i'll try replacing the marker interrupt or headlight switch next.
  10. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    does it happen with the trailer hooked up? or all of the time?
  11. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    Try unplugging the tail lights on the truck. See if they work with the tail lights not plugged in. Sounds weird, but is a common problem.
    Martin
