no oil in wheel hub
Discussion in 'Questions From New Drivers' started by kay_ray, Oct 2, 2019.
  1. kay_ray
    kay_ray Medium Load Member
    492
    1,236
    Jun 6, 2019
    hey guys so i was checking my trailer wheel hubs today because i smelled something burning after driving through those wv hills .all 4 hubs were empty . its a great dane 2016 with tire max inflation system. what do you guys think are they greased packed hubs or am i looking at some big problems . the hubs are really dark with no markings for full or empty .got freshly dotd 20 days ago .any help will be appreciated
  3. Hayfieldmn
    Hayfieldmn Light Load Member
    158
    239
    Sep 10, 2016
    Does it say min and max oil level on the clear plastic thing and is there a rubber plug in the center?
  4. kay_ray
    492
    1,236
    Jun 6, 2019
    no no markings and no rubber plug
    stillwurkin Thanks this.
  5. Hayfieldmn
    158
    239
    Sep 10, 2016
    I'd say there grease filled then. I dont know a whole lot about them.
    Intothesunset and kay_ray Thank this.
  6. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    It’s more likely you rode the brakes too much and they got hot and that’s the source of the stench.
  7. kay_ray
    492
    1,236
    Jun 6, 2019
    used jake break most of the downgrade but the brakes are brand new and little tight that might be it .
    Lepton1 and Intothesunset Thank this.
  8. Just passing by
    Just passing by Road Train Member
    1,176
    3,139
    Feb 25, 2017
    I am confused. Are the hubs self contained, where there's no plastic cover to see oil level? Have you checked in between the wheels for oil stains? No mess underneath on axles? Having no hub oil is serious trouble ahead.
  9. snowwy
    snowwy Road Train Member
    20,591
    13,311
    Jul 6, 2009
    Well. If the hub goes dry. There's only 2 places for it to leak.
    On the outside. To which you'll see oil splattering the rims.
    On the inside. Grease soaked brakes.
    In other words. Stick your head down inside that trailer and look at the brakes. Like a driver is supposed to do as part of their inspection process.
    If you don't see any oil outside or inside. You're golden. And your probably smelling very hot brakes.
    And while you're inside looking for grease. Check the brake gap between shoes and drums. Another thing you should be looking at anyways. If you see any gaps. Those brakes don't have working adjusters and need to be adjusted.
    Out of adjustment brakes will also cause your brakes that still have a good adjustment to work harder. So they get hotter. And can release a smell.
    There's a distinct smell difference between hot brakes and oiled brakes.
    heyns57, kay_ray, Lepton1 and 3 others Thank this.
  10. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    If there is no oil plug, they are grease packed, simple as that. many newer trailers are.
  11. Dave_in_AZ
    414,519
    Hub no oil typically results in axle no wheel lol.
