No or low air flow, no heat but ac works
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by CDL CPL, Apr 23, 2020.
  1. CDL CPL
    CDL CPL Light Load Member
    186
    63
    Aug 14, 2017
    Iowa
    Ok so many questions I hope you can help with.
    I'm wondering what makes you think that? Where is it located and is there anyway to test it before replacing it?
    Any help is appreciated!
  3. CDL CPL
    186
    63
    Aug 14, 2017
    Iowa
    Ok so update..the ac has pretty much started working again but still no heat in the cab whatsoever. The bunk gets hot just fine.
    We have replaced the heater core already. Does the evaporator coil have anything to do with the heat? I read that simply checking a few hoses for hot or coldness can help determine what's the problem. Winter is coming and having only bunk heat just won't work.
  4. IH Truck Guy
    4,592
    52,840
    Mar 2, 2008
    Purgatory
    Are all the shutoffs open??
    They would have closed them to replace the heater core.
    Rideandrepair Thanks this.
  5. CDL CPL
    186
    63
    Aug 14, 2017
    Iowa
    We replaced the heater core ourselves and drained all the antifreeze at the same time.
    Honestly I wasn't aware of any valves, that probably would have made things much easy on that repair. It won't hurt to check so where are these valves your talking about?
  6. IH Truck Guy
    4,592
    52,840
    Mar 2, 2008
    Purgatory
    If you have them, they will be where the heater hoses come out of the motor.
    Also for the low air flow,replace the cab air filter.
