nox sensors are plug and play on DD15... these devises use j1939 data link when talk with ACM
No parts?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Oscar the KW, Jun 24, 2021.
Page 18 of 18
Cummins Nox has a core because they are remanufactured. Most often the module is reused and a new probe is spliced on. There is a very small amount of platinum in the probe.msh and Diesel Dave Thank this. -
Goodysnap Thanks this.
Master cylinder. Take it apart measure the bore, hone a little if necessary. Measure ID try to get some o rings. Try to find a diameter of cup seal. Take the piston snd such down to NAPA. Cross reference some brake master cylinders that may have same bore and stroke.
Or a clutch slave cylinder. If you find one buy it snd use the parts in yours. Just some ideas. Hope you can get it rolling.haycarter Thanks this. -
3 weeks in freightliner awaiting front end part's.TBS!
Page 18 of 18
