No power. Poor fuel economy.
Discussion in 'Volvo Forum' started by Amram, Aug 27, 2018.
  1. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    Did you look in the fuel tanks for air coming out of the fuel returns
  3. KB3MMX
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    Have you cleaned or replaced the boost sensor also
  4. KB3MMX
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    That's not soot, it's dust that made it past your air filter. Not good.
  5. Amram
    Amram Medium Load Member
    448
    235
    Feb 4, 2017
    It was black like soot.
    KB3MMX Thanks this.
  6. Amram
    448
    235
    Feb 4, 2017
    Replaced that back in January. I have not checked the fuel tanks for air yet due to my tanks having some mesh cages in them which are proving to be quite difficult to remove.
  7. KB3MMX
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    Yeah understood. It's not soot, it's dirt.
    There is no soot entrance to that part of the turbo between it and the air filter.
  8. KB3MMX
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    You have to remove. It is possible to remove the anti siphon screens.
    This is critical to seeing if your cups are still bad.
    Once you remove the screens;
    Shine a flashlight in there and locate the return line, it's shorter and higher up in the tank. Air bubbles coming out = Bad Cups.
  9. Amram
    448
    235
    Feb 4, 2017
    The cups were replaced 2 months ago with the injectors. I will try to yank them out and look when I actually get some dry weather.
    KB3MMX Thanks this.
  10. KB3MMX
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    Yeah it's not unheard of to have a truck that just had cups Changed by Volvo mechanics to have them leaking right in the parking lot before it's even driven away.... Requiring them to be changed again.
    The cups on these Volvo Motors are just flat-out pathetic....
  11. Amram
    448
    235
    Feb 4, 2017
    The cups and the inectors are flat trash. This will be my last green motor. Next truck gonna have the x15 cummins. Done with this garbage.
    KB3MMX Thanks this.
