No power. Poor fuel economy.
Discussion in 'Volvo Forum' started by Amram, Aug 27, 2018.
  1. Amram
    Amram Medium Load Member
    448
    229
    Feb 4, 2017
    Most places are that biodiesel blend crap. It is paradise for critters. :(
    KB3MMX Thanks this.
  3. windsmith
    windsmith Road Train Member
    7,296
    6,010
    Sep 2, 2011
    NEPA
    Sounds like a plugged air filter or some other intake restriction. Not enough air = no power and poor fuel economy.
  4. Amram
    448
    229
    Feb 4, 2017
    Been running the K&N filter. Might go back to the paper filter.
    KB3MMX and x1Heavy Thank this.
  5. windsmith
    7,296
    6,010
    Sep 2, 2011
    NEPA
    That might also be an issue. The ECM expects the paper filter. Any mods can throw it off.
  6. Oldironfan
    Oldironfan Road Train Member
    5,778
    5,511
    May 22, 2017
    What ever air filter you use, you need to look inside the intake tube when it's off. If you have dust inside the tube, your engine has been sucking dust into your cylinders. Make sure you grease the air filter seal.
    Black goo in fuel filter is most like from asphaltine. It's not algae it's fuel that is seperating. Thanks to bio fuel shelf life. But bio blend does put lubrication back into the ULSD, and is good for cleaning injectors.
  7. nax
    nax Road Train Member
    1,999
    2,240
    Dec 14, 2016
    Ooohhhh...
    You do realize K&N filters have oil in them. I'm always amused that people believe these gimmicks, yet never question why high performance cars don't have k&n as factory install.
    Your intake sensors might be contaminated, leading to incorrect air/Fuel mix ratio
    KB3MMX, uncleal13 and x1Heavy Thank this.
  8. Oldironfan
    5,778
    5,511
    May 22, 2017
    You do realize that k&n truck filters are dry no oil, yet still washable right?
  9. nax
    1,999
    2,240
    Dec 14, 2016
    I had no idea.
    I don't use k&n filters, but I've seen them selling a post wash oil spray
    x1Heavy and Oldironfan Thank this.
  10. Amram
    448
    229
    Feb 4, 2017
    Is the d13 susceptible to asphaltines since it is not common rail?
    KB3MMX, x1Heavy and 25(2)+2 Thank this.
  • Draft saved Draft deleted
