No power to auto shift pad in 06 780
Discussion in 'Volvo Forum' started by moblue, Jul 20, 2016.
  1. moblue
    moblue Light Load Member
    130
    48
    Aug 8, 2010
    Ran into an issue of the truck not starting. Turn key on and no lights showing on shifter pad at all. Truck won't turn over
    Any ideas?
    Thanks.
  3. CruisingAlong
    CruisingAlong Medium Load Member
    374
    441
    Oct 17, 2014
    Tampa , FL
    I had a different issue on my 06 780 but a good place to start until more experienced chime in.
    On the battery is a few 3 or 4 power supply wires connected to positive side of the battery.
    Those go bad and a new connector spliced in. Pretty easy to check and do
  4. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    if you have no power to shift pad than no power to trans check all the connections on top of the batteries and all fuses on top probably burnt fuse or broke connection on top of batteries
    Rob100100 and CruisingAlong Thank this.
  5. CruisingAlong
    374
    441
    Oct 17, 2014
    Tampa , FL
    @nasriza is the one who diagnosed mine as those same connectors and kept me rolling. He is very knowledgeable and a big asset to us volvo owners.
  6. little cat 500
    2,048
    1,094
    Jan 17, 2010
    Abbottstown PA
    if ya had a stick wouldnt have that problem lol
    slickWillie1980 and boneebone Thank this.
  7. slickWillie1980
    slickWillie1980 Medium Load Member
    420
    35,545
    Sep 2, 2015
    Mt Olive, NC
  8. Rollin'Diesel
    Rollin'Diesel Bobtail Member
    14
    7
    Dec 8, 2015
    Thomasville
    Your fuses for the Eaton autoshift may actually be under the hood, in the harness against your firwall, beneath the air governor.
    Check your shifter harness that runs around your seat and through your floor mat.
    Also check the transmission harness. I have seen a few similar issues caused by damaged terminals in the two plugs under the cab. These two plugs are located, drivers side, under the cab, above your batteries towards cab signal marker.
  9. dorlia2
    dorlia2 Light Load Member
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    Did you fix the problem
