No Power to Datalink Connector
Discussion in 'Freightliner Forum' started by hammershark1, May 16, 2013.
  1. hammershark1
    hammershark1 Bobtail Member
    6
    Dec 1, 2012
    I have a 2006 Columbia 14l detroit with the diag connector on the left side of the driver seat. There is no voltage on the 12volt feed, had a qualcom in it that was removed, but had power untill some point after that. All the old qualcom wiring is unhooked except the two datalink wires that attach under the left access panel behind the drivers door. Checked all the fuses I could find but all are ok, and all is well with the rest of the truck
  3. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    the fuse you are looking for is in the fuse box in the "b"pillar behind the driver seat.it is marked "data"10 amp i think.good luck.
    mhyn Thanks this.
  4. hammershark1
    6
    Dec 1, 2012
    Looked all over for it but can't seem to find a fuse box back there
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    it is powered from dr. side pillar fuse panel (bat power)
    Grexha Thanks this.
  6. hammershark1
    6
    Dec 1, 2012
    Found it, thanks to for the replies, thought the fuse box was a module or the like. Fuse was blown and all is well
    Grexha Thanks this.
  7. Ray169
    Ray169 Bobtail Member
    What about for a 97 kenworth T600.
  8. Grexha
    Grexha Bobtail Member
    Hello.
    I have the same issue where mine doesn’t have power. I can’t seem to find the fuse in the Pillar behind drivers seat. Can you send a picture of what it looks like or where exactly it’s located because I’m having hard time finding it.
    Thanks
  9. Mveal72
    Mveal72 Bobtail Member
    What about on a 2000 peterbilt 379 ddec 4
  10. harold6091
    harold6091 Light Load Member
    120
    135
    Dec 25, 2018
    thanks for this post
