no power to fan solenoid
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bowhunter67, Jun 24, 2017.
  1. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,471
    Nov 7, 2007
    Possum Booger, Alabama
    Good deal, glad you found the problem.
    bowhunter67 Thanks this.
  3. Lalito.1234
    Lalito.1234 Light Load Member
    123
    32
    Dec 1, 2015
    irwin,il
    What shop found the problem
  4. Lalito.1234
    123
    32
    Dec 1, 2015
    irwin,il
    I have an isx cummins 2009 t660 and my engine fan wont turn off ever -.-
  5. Uvaldo35
    Uvaldo35 Bobtail Member
    did it work even when the solenoid wasnt receving power?!
  6. Uvaldo35
    Did it work even tho it wasn’t receiving power to tue solenoid? Mine has power to some other temperature solenoid not sure what that is but no power to the solenoid when I turn my switch on?
  7. DEVINKLUG301
    DEVINKLUG301 Bobtail Member
    14
    9
    Jan 31, 2022
    Im having a similar issue but instead i cant get my fan to come on. Im not getting power at the solenoid and checked all fuses
  8. MARE
    MARE Bobtail Member
    12
    Aug 7, 2014
    I just changed ecm that was flashing code 25 which means all good but also bad power supply or ground and at certain moment didn't want to start anymore. I'm having 1995 Fld Detroit 12.7 with ddec 3. Instead of getting another ddec3 I decided to get ddec 4 reprogramed to work on my truck. Today I installed ddec4 and truck didn't want to start. I changed fuse plug at power cable with plug ring that I assume was bad and also I changed ring plug for the ground (there are two wire for ecm ground, why 2?) after that I tryed again and after little cranking, engine started! But fan was on. After builed up the air and warm the engine I tryed with my fan clutch switch to try on and off witch usually was giving some kind of sound before, now nothing. Is it ddec4 ecm that was not properly programmed or I should search for the ground of the fan clutch?
