No power to plow lamp marker lights.
Discussion in 'Freightliner Forum' started by bowtieboy77, Oct 24, 2024.
  1. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    Have a 2017 114sd that is factory wired for plow lamps. I have no power to either plow lamp marker light. The plow lamp marker light relay and fuse in the box on left fender is good. I assume power goes from there to the body controller under cab? Vin isJHJM4979 if i could get a wiring schematic it could also help considerably.
  3. AModelCat
    158,921
    If its controlled by the body controller you might need that option enabled if this is a new install.
