I motor is bxs24244
Some times i feel it has little power
The turbo boost sits at 30 psi does not go over
When it working like it should it gos up to 40 psi
And it pulls great
no power
Discussion in 'Kenworth Forum' started by anselmo garza, Sep 8, 2013.
Is the check engine light on? I think when there is a code the ecm will de-rate and you will not make over 30psi of boost.
No check engine light.I had it check no codes,passed all tests done to it.
I put a new fuel pump
Pump Spring kit
New acuators
Head wire harness
Most of its fuel lines
Both pressure valves at primary filter housing -
When mine ate an exhaust sleeve I got erratic boost until it finally settled in at 28-30 psi. had to replace turbos.
How much did your turbos cost?
I got lucky a buddy of mine was building a sled puller out of his Acert and sold me his used ones for 1500.00 for everything mounts, pre-cooler, manifold everything. New one are around 4000.00 for just the turbos. There is a lot cheaper way to fix it. I'll send you a PM.
