No rear extended fairings
Discussion in 'Ask An Owner Operator' started by nsxftw, Jul 18, 2014.
  1. nsxftw
    nsxftw Light Load Member
    192
    39
    Dec 2, 2011
    n/a
    Hey O/O, I am planning to buy this 07 Freightliner columbia 58'' sleeper that comes with apu. I have a question, does it really effect on your fuel MPG without having extended fairings on the both side of rear end. I am planning to pulled 53'' Dry van. I'd appreciated for some of opinions. Thank you:biggrin_25525:
    Simpledriver Thanks this.
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    The bolt holes are allready there ,You can buy them at J/yard and just bolt em on, it will help some pulling a van but you can CK. the mi. then put them on and see how much it helps?
  4. Simpledriver
    Simpledriver Light Load Member
    69
    26
    Nov 9, 2013
    It does. You save like 40 dollars a day. Roughly.
  5. Chewey
    Chewey Light Load Member
    140
    72
    Feb 10, 2012
    It does affect it about 1 to 2 percent. You have to keep the trailer pulled up pretty close to the cab to see a difference. If you plan to have someone install them or will not keep the truck over two years it will not pay.
    nsxftw Thanks this.
  6. CHUBBYBUNNY
    CHUBBYBUNNY Light Load Member
    62
    24
    Oct 11, 2013
    Yeah they make a difference but not sure how much. I have no idea how much they cost to replace. If you haven't bought the truck and you must have that one then why not have the dealer put new fairing extenders on it as part of the deal?
    nsxftw Thanks this.
  7. nsxftw
    192
    39
    Dec 2, 2011
    n/a
    Thanks for all your input. This truck is on sale from Ryder and has 689k miles for $34k. It's is 07 columbia w no emission regen system.
    I called local freigtliner dealer and they said they do see the parts for that vin#.
  8. nsxftw
    192
    39
    Dec 2, 2011
    n/a
    I meant to say they do not see the parts for it.
  9. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    nsxftw Thanks this.
  10. Chewey
    140
    72
    Feb 10, 2012
    I think you would be better off with this truck as it has no regen system. Dont worry about fairings.
    nsxftw Thanks this.
  11. CHUBBYBUNNY
    62
    24
    Oct 11, 2013
    Definitely go with truck without a regen system but this isn't the only truck out there without a regen. I am sure there is another Cascadia with fairings and similar specs. Buy what you want with the features you want. There are plenty of trucks out there.
    nsxftw Thanks this.
