No reception
Discussion in 'CB Radio Forum' started by cb_noobie, Aug 12, 2013.
  1. cb_noobie
    cb_noobie Bobtail Member
    I have installed an older cobra 40 channel CB in my scout and have a single fire stick antenna hooked up. The radio will key up as I can tell by the gauge or meter that moves when I transmit but I cannot ever get the response. Am I not transmitting? Am I just not receiving? Is the antenna bad? I did buy the antenna at a yard sale and the radio did work in another truck with a different set up. Any help would be very much appreciated.​
  3. Flatbedn
    Flatbedn Road Train Member
    1,307
    784
    Nov 12, 2012
    Squelch may be too high causing it to block incoming signals.
  4. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    Do you least have static?
    Like Flatbedn said, set squelch and RF gain till you do.
    Still nothing? assume it set to PA or external speaker in wrong outlet.
  5. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    Try an external speaker. Sometimes the internal speakers go bad.
  6. Ridgeline
    22,659
    121,054
    IT maybe a mic problem, you need to plug in the mic to make it work but I know you have it plugged in so it could be a broken wire in the cord or a problem with the mic switch itself.
    Another CB trick I use when I have this problem is not to worry about the audio but the meter, by first having someone with another radio key their mic and see if you can see the meter move. If you can't, then go to the controls and see if you can adjust the RF gain to see if it moves. If nothing then you want to rule out the antenna, then take a piece of wire and stick it in the center of the coax plug to see if you get a signal.
  7. Cswann1
    Cswann1 Bobtail Member
    45
    15
    Dec 31, 2012
    What SWR are you seeing? If the radio did OK in another truck, and I assume with another antenna, then that would be something to look at. I know from experience with Frieghtliner Cascadias that bad antenna systems make a perfectly good radio useless.
