no secondary air.
Discussion in 'Peterbilt Forum' started by dubtownmechanic, Nov 19, 2014.
  1. dubtownmechanic
    dubtownmechanic Bobtail Member
    2013 peterbilt is not getting secondary air. primary airs up to 125 as it should secondary gets none. tried idling up and still nothing. thought maybe the lines were froze left tractor in the shop infront of multiple heaters over night primary air tank blew out all the condensation secondary still had no air. I'm now at a loss. I'm new to working on these trucks and just dont know where to go from here. any advice would be appriciated.
  3. Hammer166
    7,465
    27,081
    Aug 18, 2007
    ~8600+' and loving it!
    There's a check valve on the supply to that tank, must be stuck closed.
  4. 1boater12
    1boater12 Bobtail Member
    7
    4
    Nov 19, 2014
    Also check to make sure its really not getting air. You dont have a a gauge problem do you?
  5. dubtownmechanic
    no gauge problems, the air tanks arent getting any air at all. i havent had an oppertunity to try the other suggestion yet having 6 other trucks to work on but i will as soon as i get a chance. thank you both.
  6. resistol
    resistol Bobtail Member
    4
    wheres the check value located
  7. resistol
    4
    I've got the same problem this evening, I got a 2017 587 with #1 tank full of air and #2 dead empty of air, I parked it it was totally functional. please help me, tried tapping on the value on the fire wall, no response at all, still being played here.
  8. Hammer166
    7,465
    27,081
    Aug 18, 2007
    I think I saw on another thread a while back that Pete has the check valves in the dryer. Not going to swear it was Pete, but I think it was.
