No tach, tried new sensor.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by BryRylanKW, Sep 9, 2011.
  1. BryRylanKW
    BryRylanKW Light Load Member
    118
    17
    Feb 1, 2011
    cape cod MA
    My 89 w900b 3406 cat has had no No tach from when I bought it, tried a new sensor today still nothing, I think the gauge its self maybe bad because when i turn the key on it still at 1000 and does not change when i turn it off or on its just stuck at 1000 rpms.
  3. bender
    bender Road Train Member
    2,105
    1,360
    Jul 20, 2010
    Don't Kid Yourself
    Each time you turn the key to the run position, your tach should self check or show needle movement. I would start by verifying power (12v) and ground at the tach head before you condemn the head.
  4. BryRylanKW
    118
    17
    Feb 1, 2011
    cape cod MA
    10-4 Will check tomorrow...
  5. BryRylanKW
    118
    17
    Feb 1, 2011
    cape cod MA
    have 12V at one terminal on the tach plug. time for a new tach?
  6. bender
    2,105
    1,360
    Jul 20, 2010
    Don't Kid Yourself
    First verify ground at another terminal as the tach head also grounds through the plug.
    If you have both power and ground, then the tach should self check when the key is cycled on.
    To verify ground connect test light clamp end to known good 12v and probe for ground (use your test light backwards)
  7. BryRylanKW
    118
    17
    Feb 1, 2011
    cape cod MA
    ok will try that and report back. the grounds labeled so it should be easy to test it real quick
  8. Big Don
    Big Don "Old Fart"
    17,996
    35,644
    Sep 8, 2007
    Utah's DIXIE!
    FWIW, with my last company, I got assigned an old truck that the tach did not work on. I wrote it up three days in a row, and the shop never even looked at it. So I stopped writing it up, figuring it was a waste of time.
    I went out on back surgery and another guy was driving that truck. Got pulled in for an inspection and got an OOS for the tach not working. Then it got fixed.
    Of course he got in hot water with the company. We had a standing policy of days off for an OOS. When I came back to work and found out about it, I went into the files for the write ups for that tractor. They had been removed.
    I know this has nothing to do with you getting your tach working, it is just something that has always eaten away at me, and this looked like a good chance to bellyache about it.:biggrin_25510:
  9. BryRylanKW
    118
    17
    Feb 1, 2011
    cape cod MA
    must be the gauge cause the grounds good at the tach.....
  10. bender
    2,105
    1,360
    Jul 20, 2010
    Don't Kid Yourself
    Yep, you narrowed it down to the guage.
