Noise in FM Radio Speaker
Discussion in 'CB Radio Forum' started by Michael 247, Jul 4, 2019.
  1. Michael 247
    Michael 247 Heavy Load Member
    893
    4,677
    Nov 20, 2017
    Dublin Va
    I installed a CB in a 1990 White /GMC..When I key up it makes noise in the FM Radio Speaker..if I leave the FM Radio off the CB works good and does not put noise in the FM Radio Speaker..How can I fix this problem ?
  3. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Keep stereo turned off when using CB...There is no fix...and the more power you run, the worse it's going to get...
  4. Ridgeline
    22,389
    116,329
    Replace the coax.
  5. Michael 247
    893
    4,677
    Nov 20, 2017
    Dublin Va
    it's a new coax cable from CB Shop
  6. Ridgeline
    22,389
    116,329
    Then get some chokes and put it on the coax, you have a ground problem from what is called common current mode, which makes the outer shield of the coax as part of the antenna.
  7. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    First make sure your antenna is properly RF grounded. Do this with a multimeter's Ohm function, with one probe on the antenna coax's outside shield such as where it is in contact with the mounting screw collar that normally is attached to the radio, and the other probe on the vehicle's chassis ground. If the Ohm value is not zero, then try installing a short piece of copper mesh to better ground the antenna to the vehicle.
  8. Michael 247
    893
    4,677
    Nov 20, 2017
    Dublin Va
    I put a ground wire from antenna bracket bolt to a bolt on cab..the noise I'm hearing is talk back..i can hear what I say through the FM Radio Speaker..i will just leave FM Radio off until I get a CB Shop to check it..Thanks for all the replys
  9. Method240
    Method240 Light Load Member
    52
    30
    Jun 9, 2019
    TN
    it's grounding. I've run KWs without that. the FM isn't grounded
    Michael 247 Thanks this.
