Anyone ever have noise in geartrain area sounds like aircompressor but changed aircompressor same noise. You can hear the noise when aircompressor is unloaded but louder when compressor is loaded. sounds almost like a rod knock but ive pulled the pan down checked ristpins the best i could replaced both rods and mains. I also ran the overhead. It is a cat c-15 bxs engine.Also checked for broken rocker arm and vva housing bolts and studs.
noise in gear train cat c-15
Discussion in 'Peterbilt Forum' started by Gear head, Apr 12, 2012.
io have a c15 sounded like a card in the spokes of a bike had broken bolt holding turbo to exhaust man.
broken or hairline crack so i know what to look for
I had the bolts on idler gear come loose once . pulled peanut cover off and put new bolts in.noise went away.
did you figure it out cause i have the same noise in mine....
