Noise in top end of cummins isx
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by lciambotti1, Sep 29, 2019.
  1. lciambotti1
    lciambotti1 Light Load Member
    117
    22
    Mar 6, 2015
    Ok, so my driver called last night and said the engine started losing power, and the oil pressure dropped to 20 lbs. He restarted it with me on the phone and he said it was making a rattling noise. Rode up to the truck and started it. It sounded fine, and oil pressure was back up to 35 lbs. No bottom end knock. (Rods, Mains, and oil pump) replaced about 50K miles ago. Revved it up a bit and there was a squeal and a rattle, sounded on the top end, and oil pressure bounced up and down. Shut it down and I guess Ill get it towed tomorrow. Any thoughts (wiped out cam bushings, cam)? The oil pressure going down to 20 lbs confuses me.
  3. Goodysnap
    Goodysnap Road Train Member
    3,716
    9,022
    Jul 12, 2017
    Age, milleage, what series ISX?
    Spun cam bearings are common on high milleage CM870 and 871.
    Pull the valve cover and have a look, makes sense with the oil pressure fluctuations.
  4. lciambotti1
    117
    22
    Mar 6, 2015
    It’s a 8520 cpl. 2006. 640k miles on it. And I do have a weak number 3 injector.
  5. lciambotti1
    117
    22
    Mar 6, 2015
