Noise in transmission or clutch
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mike216, Feb 23, 2022.
  1. mike216
    mike216 Bobtail Member
    44
    13
    Dec 15, 2013
    Cordova,Md
    Have a 2015 389 Pterbilt.600 Cummins with 18spd autoshift. 520000 miles. When decelerating, a bang noise can be heard. You can run around yard,doesn’t matter what gear or speed or rpm. when you let off the throttle you can hear a bang.Sounds like in clutch. Checked all mounts. Everything looks tight.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,429
    6,465
    Aug 26, 2014
    I never head a clutch do that. Check rear suspension bushings. Check for metal in rears. Does it do it with the power divider locked? Does it do it in 15 through 18th gear?
  4. mike216
    44
    13
    Dec 15, 2013
    Cordova,Md
    Thanks , all that looks good. The noise sounds like it’s under firewall.
  5. rustymike
    rustymike Bobtail Member
    28
    29
    Dec 17, 2021
    If that truck has a driveshaft support bearing, check it for play in the bearing and the rubber surrounding the bearing.
    Magoo1968 Thanks this.
  6. BoxCarKidd
    4,429
    6,465
    Aug 26, 2014
    All the transmission and flywheel bolts tight. Housings not cracked?
