noise when windshield wipers on
Discussion in 'CB Radio Forum' started by Bighig, Dec 21, 2011.
  1. Bighig
    Bighig Bobtail Member
    45
    4
    Nov 5, 2011
    Easley,S.C.
    when my wipers come on I hear noise thru my external speaker . Galaxey 959, k40 mic ,k 40 magnet antenna .please help :dontknow:
  3. Tricky Rick
    Tricky Rick Light Load Member
    177
    91
    Oct 25, 2010
    Northwest Mississippi
    Where are you getting your power source? Try another circuit, or get an inline filter, available at most cb shops.
    Bighig Thanks this.
  4. Bighig
    45
    4
    Nov 5, 2011
    Easley,S.C.
    the power is coming from the factory wires over head but not using the factory coax.the truck has A cut out spot for a cb
  5. Tricky Rick
    177
    91
    Oct 25, 2010
    I would put an inline filter between the radio and the power. Sounds like my old '07 Columbia. The filter helped a lot.
    Bighig Thanks this.
  6. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    I never had much luck with those in-line noise filter gizmo's...If you get one and find it don't work... try running a ground strap off the windshield wiper motor to the frame or firewall...You may also try running a ground strap from the external speakers mounting blots to the frame or firewall if you have it mounted to plastic.
    Bighig Thanks this.
