Non-tuneable antenna
Discussion in 'CB Radio Forum' started by reddemon71, Apr 1, 2008.
You can tune a Francis. You have to cut it. What's the problem?
Back to the original poster. Find a good shop. Francis has always been known as an antenna you stick on, and forget it. Provided you have the proper co-ax lengths, and no internal problems.
Other than that, if you have the proper co-ax length. have you coiled it up? Not a good idea. Even shielded leaks. -
Wrapped it in black tape real tight. I used a Dremel with a cutting disk.
The right length of co-ax is increments of 3 feet. The best I have found is 18 Feet. -
There lies your problem. Your coax is WAY too short. Not to mention, of a very odd length.
Here's my take on your antenna. If you drive a KW T-600 it's safe to use 5 ft. If you drive a Freightliner Columbia...stick with 4 ft.
Either way, you want MORE coax...lots more. -
go with 18' coax, that might not be the problem though, it could be many things..... and you actually can wrap a coax cable, but the loops should not be smaller than a 12" radius a wise cb tech, old school ham told me that, and i have my dual coax wrapped under each seat the loops are a little larger than the 1' loops and it works great, i get out amazing, have never got negative reports, only great reports from people a lot further than i thought i was going to reach.... oh you could also try a wilson silverload, it is tunable and its still your fiberglass... or try a wilson flex.....?
Never really knew a coax had that much impact, I drive a volvo, I'll pick up a 18ft and try that too -
coax is just as important as an antenna and a radio... its all one item when hooked up and it works that way... it makes an impact and is normally the cause when you can find no other....
I'd rather be safe than concerned about my "tune" job. Too easy to snag a loose coax and fall out the cab, head first.
