Norcold Fridge VNL 780
Discussion in 'Volvo Forum' started by d281833, Jun 25, 2012.
  1. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Having a problem with the fridge in this thing. Voltage is fine but if the truck's shut off fan will still run but the compressor won't engage. Pull it out and tap the control module and it will work for a couple days, Volvo gonna replace with a new fridge. Anyone else?
  3. d281833
    881
    919
    May 15, 2012
    Finally just replaced the fridge. Apparently bad run of fridges for about 5 months, tried to wire them differently with the low voltage disconnect. Seems fine now, hopefully.
  4. nutcase
    nutcase Light Load Member
    259
    100
    May 2, 2010
    Meridian, ID
    Was this in a new(er) truck?
  5. d281833
    881
    919
    May 15, 2012
    Yeah new truck. Fridge was pooched from the get go. There was a fix put out in a service bulletin pertaining to disconnecting an extra wire they installed for low voltage disconnect but it didn't work, so they replaced the fridge.
  6. d281833
    881
    919
    May 15, 2012
    ok, on my third fridge now. see how this one lasts.
  7. kw08t660
    kw08t660 Bobtail Member
    10
    Dec 6, 2012
    CA
    am having the same problem what do you recommend me to do?should i just buy a new one or there's someone out there that can fix it.
  8. d281833
    881
    919
    May 15, 2012
    Well depends how old it is. They're warrantied from Norcold for 2 years. The fix was that you had to pull the " P " wire off the back which from what I hear worked for some and also easy to do. If that didn't work they have to replace the fridge. My other one's were manufactured in 2011, this one now was built in 2012 and came with a note from Norcold saying that it's been rewired. I would say because they were having such a bad run of fridges. My 2006 I never had a problem, they should have left them alone. That being said it's as frustrating as hell, and for buying one they're a 1000 bucks.
