North Dakota - Crude oil or Water
Discussion in 'Oilfield Trucking Forum' started by bonder45, Nov 14, 2019.
  1. bonder45
    bonder45 Road Train Member
    1,160
    2,812
    Oct 2, 2011
    Williston, ND
    I’ve finally got my Visa and made my way down to Williston, North Dakota.
    Experienced Albertan ready to take on the American market seeing as ours is going in the ####er.
    I’ve spoken to a fair amount of guys down here so far but I wanted to get some insight from your guys IF there are any owner operators on here.
    I currently am just waiting on one last number before I can get my ND license. I have my own truck and tanker trailer.
    Reason for edit: Skirting profanity filter
    truckdriver31 Thanks this.
  3. Rounded_nut
    Rounded_nut Light Load Member
    92
    107
    Feb 25, 2018
    When I worked up there I preferred oil, usually not a cluster, oil doesn't freeze valves shut.
    rabbiporkchop Thanks this.
  4. LDLWells
    LDLWells Heavy Load Member
    782
    1,209
    Jan 14, 2019
    I know a company that does both and is only oo
  5. bonder45
    1,160
    2,812
    Oct 2, 2011
    Williston, ND
    Care to elaborate?
  6. blue1005
    blue1005 Light Load Member
    157
    83
    Apr 18, 2015
    I would assume with water you always go over the top in winter.
  7. Lou-zr
    Lou-zr Bobtail Member
    I've been at it here in the Bakken going on 9 years as a company driver, mostly doing production water to disposals with a gear pump. The salt content keeps freezing issues to a minimum, unless it gets 30+ below zero & you can't unload for several hours.
    I also occasionally do fresh water injections with a vac. You need reliable logistics in sub-zero weather for fresh so you know it's not gonna be sitting on the truck for very long.
    Things are on the slow side right now. It just seems to be due to the typical political uncertainties leading up to an election year.
  8. blue1005
    157
    83
    Apr 18, 2015
    True, but they are still hiring, better then Oklahoma who is laying off.
  9. LDLWells
    782
    1,209
    Jan 14, 2019
    That would be recruiting supposedly. But I would look around Stanley or PM me
  10. bonder45
    1,160
    2,812
    Oct 2, 2011
    Williston, ND
    I’m asking so I don’t think it would be recruiting.
    Ah, I have a fully enclosed and heated pumper box so I’ve never had any issues up in Alberta. Even hauling cold lake water on a -30 day.
  • Draft saved Draft deleted
