Not good at gear ratio, and fuel mileage. 3:21 gears
Discussion in 'Ask An Owner Operator' started by Phumac, Sep 11, 2018.
Page 2 of 3
Phumac Thanks this.
If it's on 22.5 lo pro rubber, 3.21's will be about 1300 rpm at 65. You'll be downshifting at speeds below 65 to climb and pass. Fuel economy should be near optimum. I have no idea what running that low an RPM does for the DD after treatment systems.
Phumac Thanks this. -
Just remember that the lower numeric number of the rears, the higher the truck is actually geared.
So for example when you pull out in low gear or back up in Reverse with say 3:90 or 4:11 Rears vs 3:21 rears, the 3:21 Rears may feel like you are in a higher gear. The rears that are geared lower will actually make you feel like you have more power for pulling Hills.
BUT, when you cruise down the highway the 321 Rears will give you a lower RPM at 65 or 70 or whatever speed you cruise at and a faster top speed.
The road ranger website has a road speed calculator that shows what RPM's you will turn with what rear and transmission (direct or Overdrive) and tires.ChicagoJohn and Phumac Thank this. -
ChicagoJohn Thanks this.
I use this website:
http://www.roadranger.com/ecm/groups/public/@pub/@eaton/@roadranger/documents/content/ct_062746.swf
You'll have to look up the final drive ratio for the specific transmission in that truck. Fleet 10 speeds seem to be the standard .73 final. Tire size is also most likely 11R22.5
Figure 1300 RPM you'll be right around 66mph, which is fine for a dd13. They like to run between 1200-1400 when cruising so you'll get decent mpg, but they are dogs in the hills.Phumac Thanks this. -
Phumac Thanks this.
Phumac Thanks this.
Page 2 of 3
