NOT using a clutch when shifting gears on a manual trans?
Discussion in 'Questions From New Drivers' started by ichudov, Mar 14, 2012.
  1. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Double clutching?What's that?lol
  3. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    Something you should know inside and out with your years.
  4. Round2
    Round2 Light Load Member
    268
    90
    Feb 14, 2012
    WA
    CDL tests are different in every state. In WA you had better double down on every throw during the test. After that learn to feel your way around the country. When you drive a while you won't even realize the few times you use the clutch to assist. It becomes as natural as breathing, it just happens and your mind is on the traffic and your path.
  5. pattyj
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    I was joking.Figured you could see that with lol at the end.
  6. sbgogirl
    sbgogirl Light Load Member
    85
    31
    Dec 7, 2011
    Anderson, SC
    SC road test double if not every gear you don't double is 1 point...After you get CDL learn to float and do which every you like best.
  7. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    "Eaton Fuller said you should double clutch."
    Can you show me that? They DO have a video on how to float shift..... what I'm saying is they DON'T tell you NOT to float shift...
  8. walstib
    walstib Darkstar
    I float up and down as I've found it much smoother...
  9. Dstraw
    Dstraw Bobtail Member
    43
    19
    Feb 27, 2012
    Somewhere
    I just started floating after being on my own for about 6 months...definately smoother yet I still have to double clutch in certain situations. I figured out real quick when the clutch pretty much got destroyed and they had me drive 800 miles to a particular terminal...it wasnt a flat run either.
  10. pattyj
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Isn't double clutching required by law to teach that in schools?
  11. pattyj
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    So how did the clutch get destroyed?
