2015 cascadia evo in shop for spn 3364 active. Had a spn 4364 code a few months back but went inactive same day. This def quality code came up two months ago, also went inactive same day and then again today. Checked into shop to diagnose since repeatedly came back but want to have some knowledge on this before I just ok repairs. I know the end all be all could be box 1 fail but since codes go inactive, wouldn't that be unlikely? I would think the perimeters for the fault wouldn't return to normal if box 1 was failed. Would a failing Nox sensor cause either of those codes despite not having a Nox sensor code? I asked the shop to start with the doser, def filter, etc and check for buildup since that too makes sense. I guess what I'm asking is, how common is the Nox or doser the problem vs a box 1 fail? I tend to panic into thinking worst case scenario.
Nox conversion low/def quality
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Pendulum, Mar 6, 2018.
Page 1 of 3
Should note it's a Dd15
Bad engine harness will cause random codes
Pendulum Thanks this. -
Funny you say that because we've been having some issues with the Snoqualmie pass de-icer eating away at wires. Brake lights especially.
A bad Nox sensor can cause those codes. Watch the Nox readings with laptop during regen. "Driftng" values will tell you which, if any, sensor is bad.
Working2party Thanks this. -
Update: It did a successful regen but at 81% efficiency which I guess is above normal but under the 85% threshold. Nox sensors were both in parameter. No active codes, no build up of def on inlet. No accumulation of def in the box. Going to drive it and see if problem persists. I'll update this thread is something does happen.
Well, i have the same problem going on for 7 months, change one box, def metering unit, new def filter , def header, nox inlet and outlet sensor, every single sensor that has something to do with the def and I still have the same problem def quality code ... please help if you have any info? All repairs done in premier truck group Freightliner dealership ..
There’s a part called a bladder and in order to change it you have to break the def pump and replace it as well. That was the thing I changed after the one box and I don’t have any more issues. It was stuck... frightliner did it as well. After I changed everything else I mentioned. I’m thinking about sueing for misdiag.. because after $12k for one box and several visits and parts and down time: I went back on the road and 100 miles later same problem def light flashing. Went back and got the bladder and pump changed and have no problems... (keep in mind that when they check the pump and say it’s ok they don’t check that bladder)... good luck guys.. I know how frustrating it is but that was my experience..
mhyn Thanks this.
Page 1 of 3
