NOX sensor codes
Discussion in 'Ask An Owner Operator' started by Sfrappier, Jun 13, 2018.
  1. Sfrappier
    Sfrappier Bobtail Member
    10
    Feb 18, 2017
    Mechanic says I have 2 active fault codes for NOX sensor. He says I’d be able to drive and not experience derate. DD15 engine 2013 Cascadia. I know I need to get it fixed but I’ve been down 2days now need to get home. Any advice? Do any of you think I’ll be ok for time being?
  3. mover man
    mover man Road Train Member
    1,698
    1,801
    Feb 21, 2010
    If you can make it home with out a parked regen being necessary, should be good. I drove mine for a couple weeks with a check engine code for nox sensors
    Sfrappier Thanks this.
  4. Espressolane
    18,192
    113,004
    Will the truck do a parked regen? If not then you will need to look at replacing the NOx sensors. If memory serves me, it should have NOx sensors that retract during a regen. If they will not retract it will not do a regen. Not a cheap fix, but an easy one, replacing the sensors.
    If you have a Detroit shop near by, they should have the parts. It is a somewhat common problem. A dealer will most likely have them as well. Better luck at a Detroit shop getting in and changed.
  5. 389driver
    389driver Medium Load Member
    371
    1,035
    Feb 25, 2018
    Upstate NY
    Usually they wont do a proper regen with CEL on, otherwise you should be fine. My truck CEL has come on intermediatly and the our shop just deleted the code for a while till they got around to changing the sensor.
