Nox sensors replacement + regen - 10 hours of labor??
Discussion in 'Freightliner Forum' started by Lazar181, Aug 4, 2025.
  1. Lazar181
    Lazar181 Bobtail Member
    Aug 4, 2025
    Hi guys,
    I’m stuck at the Freightliner dealership as my truck went into derate due to faulty Nox sensors. These guys are charging me 10 hours of labor for nox sensors replacement and regen… Is this normal?? Other forums mention that it takes 1.5-2 hrs to replace them and up to 1hrs for regen
    cascadia4life Thanks this.
  3. 062
    062 Road Train Member
    6,233
    33,553
    Oct 20, 2013
    Need to know what engine and what the codes were.
  4. Goodysnap
    Goodysnap Road Train Member
    3,724
    9,054
    Jul 12, 2017
    How much of the 10 hrs is for diag? Ask for a breakdown of the time.
    AModelCat and wore out Thank this.
  5. xramex
    xramex Bobtail Member
    Jan 1, 2023
    You are getting ripoff. Took me like 30 mins to replace my outlet Nox Sensor and that is including watching the Step by step tutorial on Youtube. The Inlet doesn't look look like to much work either. I say 3h max including regen.
  6. 062
    6,233
    33,553
    Oct 20, 2013
    Changing the sensor generally doesn’t take too long. If it’s a Detroit and they followed all the troubleshooting steps,then it can take time.
  7. Antinomian
    Antinomian Road Train Member
    2,117
    3,342
    Feb 17, 2013
    Depends on how hard it was to get out. Sometimes they have to cut the bung off and weld a new one on.
    cascadia4life and AModelCat Thank this.
  8. AModelCat
    160,533
    If the sensor broke off that'll be where the time went. Flat rate and book times are a very general guide and go out the window in less than ideal scenarios.
  9. OlegMel
    OlegMel Medium Load Member
    433
    728
    Apr 8, 2023
    Diagnostic fee, 2 hours, nox sensors replacement 1.4hours, regen 1 hour. When nox sensors go out there’s usually a circuit or inefficiency codes. They’re not that difficult to diagnose. A lot of dealers these days like to charge 2 hours for “laptop hookup to read the codes” then they start with their tests. Sounds like these scum bags are taking advantage of you
  10. cascadia4life
    cascadia4life Bobtail Member
    43
    11
    Apr 21, 2023
    Yeah.... 10 hours for nox sensors. .. Poor guy. Feels like a ripoff. But still not cheap. Nox sensor plus Regen.... That's like 2500$ USD?
