NTC 444 running the overhead
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 704mover, Dec 16, 2020.
  1. 704mover
    704mover Light Load Member
    60
    22
    Mar 8, 2018
    I have a 1989 NTC444 Cummins. 1210 CPL. Data tag says .011 intake, .023 exhaust, T.S. zero lash injectors. Someone please tell me proper method for setting overhead. Last time I set injectors to 6 in/lbs but can't remember the A,B,C settings. Google gives conflicting OBC/IBC charts for these engines. Some show .014/.027. I run this overhead a few years ago but I'm confused now. Are the Jacobs Jake's .018? Thanks
  3. xsetra
    xsetra Road Train Member
    5,117
    6,987
    Aug 21, 2011
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    @OLDSKOOLERnWV yer being called.
  5. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    The original overhead set procedure was inner base 6 inlb .011 & .023. You used a small tool to hold the stc tappet up while setting the 6 inlb zero lash. Over time the tappet would wear & the inner base setting procedure didn't compensate for that.
    The later procedure was the outer base method. You seat the injector plunger with a torque wrench. From memory the injector sets at 90 INCH lbs. .014 & .027 on the valves. Set the injector before the valves. The ABC marks are used very differently for the 2 procedures. Outer base you set the valves & injectors on the same cylinder. Don't use the chart that has you jumping between cylinders. Just find your starting point & run the firing order.
    Does it have a c brake or a Jake?
    magoo68 Thanks this.
  6. pup
    252
    256
    Dec 3, 2011
    n.h.
    One other thing to add here. Prior to setting it you should switch the stc valve into normal time & run the engine to purge the injector tappets. Take the line off the fuel pump. Cap the pump & using an air regulator connected to the line switch the valve.
    baha Thanks this.
  7. 704mover
    60
    22
    Mar 8, 2018
    Yes Jake's. I'm still lost. Which sequence? I've never messed with the STC when running the rack before and had good results. I just don't remember which sequence I used.
  8. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    If you used 6 in-lbs which is also considered zero lash then you were using inner base method where you set valves on one cylinder and injector on another.
    With the stc and setting them zero lash you need to get the tool that allows you to hold up the STC tappet in the injector otherwise you wont get an accurate set.
    704mover Thanks this.
  9. RocketScott
    RocketScott Medium Load Member
    579
    948
    Apr 10, 2013
    Kentucky
    I have a 444xt but it's been a couple years since I ran the overhead. I have the service manual at home and can text or email pictures, just send me a message with your number or email. I have C brakes that get set at .018, not sure about Jakes. This is all I have in my notes on my shop computer:
    Injector and Valve adjustment sequence
    Bar engine in direction of rotation, clockwise viewed from the front
    Pulley Injector Valve
    A 3 5
    B 6 3
    C 2 6
    A 4 2
    B 1 4
    C 5 1
    Firing Order 1-5-3-6-2-4
    C Brake set position
    Pulley Left Hand Rotation Right Hand Rotation
    A 4 5
    B 2 3
    C 6 6
    A 3 2
    B 5 4
    C 1 1
  10. 704mover
    60
    22
    Mar 8, 2018
  11. pup
    252
    256
    Dec 3, 2011
    n.h.
    Outer base is the correct procedure for setting the overhead. what is the Jake model#?
