nucor steel
Discussion in 'Flatbed Trucking Forum' started by 5thwheel23, Jul 3, 2013.
  1. 5thwheel23
    5thwheel23 Light Load Member
    82
    22
    Jun 5, 2010
    South carolina
    how is everyones experience with this plant. specifically the one in darlington, sc as well as huger, sc. easy in and out or what? what do each of them mainly load. thnks.
  3. MJ1657
    MJ1657 Road Train Member
    7,521
    50,151
    Jan 28, 2012
    Isanti, MN
    I went to the plant in Darlington a while back. I can probably count on one hand how many women I have called the C word.The lady that worked in the scale house was that times 10.
    Loading went okay though.
    shooter19802003 and 5thwheel23 Thank this.
  4. 5thwheel23
    82
    22
    Jun 5, 2010
    South carolina
    thank u sir. what was protocol when u went. what kind of loads were they loading. maybe even where were they going
  5. MJ1657
    7,521
    50,151
    Jan 28, 2012
    Isanti, MN
    Follow the signs to the staging area and you call in on your CB with your load number and appt time. When they are ready for you they call out your number and you then pull onto the scale and go inside to get loading info.
    I hauled some big steel bars to another Nucor facility in northwest Missouri They were laid back and easy to get along with there.
    5thwheel23 Thanks this.
  6. MJ1657
    7,521
    50,151
    Jan 28, 2012
    Isanti, MN
    Appt time was very important.
    SHC Thanks this.
  7. 5thwheel23
    82
    22
    Jun 5, 2010
    South carolina
    appreciate it MJ. never hauled out of there. bout to sign on with a new company and looks like I might be on somewhat of a dedicated account with Nucor. like to have a heads up if I can.
    MJ1657 Thanks this.
  8. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    I hauled out of both quite a bit last year. Have your dispatch leave you a little window on the appointment time and have them reschedule right away if you are going to be late for any reason and you'll be okay. good facilities with good waiting areas and tarp areas. just plan to be there for 2-3 hours if you are on time. lots of trucks. If you're not on time, it's reschedule and the next appointment may be the next day.
    MJ1657 Thanks this.
  9. 5thwheel23
    82
    22
    Jun 5, 2010
    South carolina
    can u park overnight there. and have any of you noticed a company called c cross transportation while loading there?
  10. dannythetrucker
    2,856
    4,032
    May 26, 2011
    everywhere, man
    I never parked overnight, but I can't imagine anyone would hassle you since you are outside the secured area. Don't remember that name on trucks, but like I said lot's of trucks in and out.
    5thwheel23 and MJ1657 Thank this.
  11. MJ1657
    7,521
    50,151
    Jan 28, 2012
    Isanti, MN
    Like Danny said the staging area is a dirt lot outside of the secured area. It is a big lot.
