O/O Dry Van Empty Miles .... ?
Discussion in 'Ask An Owner Operator' started by LittleMissCabover, Apr 11, 2014.
  1. LittleMissCabover
    LittleMissCabover Light Load Member
    125
    83
    Sep 6, 2011
    kansas
    Hi All ! I have been contemplating parking my hopper and buying a van trailer for months now. I read on this forum about different independent owners, sharing information and ideas in an effort to help others. My current question is concerning pay rates that are given on this forum. I read in the O/O and Freight Broker forums about rates that current independent operators receive. One operator states that he runs for (example) $1.90 p/mile, while the next person states his rate is $2.25 p/mile and yet another states a rate of an even higher amount. For the purpose of my inquiry, I want us to concentrate on load board rates, not direct shipper customers. When the Independent/Operator states a certain rate on an accepted load and converts that all in rate to rate per mile, is he including empty miles to pick up that load?
    Before I leave for now, I thought of another concern of mine. Does the load confirmation state whether the receiver will unload, or if lumpers are required. If lumpers are required, does the confirmation state the lumper fee, and whether or not that fee is included in the load rate?
    Thanks to All !!!
  3. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    For your rate conformation sheet questions the answer is usually. When you haul for brokers for the first time make sure this is stated in your conformation so there are no issues. Once you get to know the brokers your pulling for that stuff is just kinda assumed unless otherwise stated. Rates come up on here all the time. There is no one answer for that. If your running local rate per mile should be higher. Local rates vary from 2-6$ per mile. Once you know your bottom line you need to set a minimum rate so you don't get burned doesn't matter if it's local or distance. I always account for my dead head miles into my rate. Other guys do not, it's a personal preference. I just figure if the truck is running and moving it's costing money for that to happen.
  4. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    why dont you rent a van for a few months to test the waters before you spend a ton on a trailer/industry you might not like.
    Depends on the load board, but most rates dont include empty miles. (assuming you have your awn authority and arnt leased on) In most cases minimizing empty miles help you out.
    As for lumpers, ask the broker before you pick it up. I tried to stay away from grocery stuff because it usually needed lumpers and they take forever to unload.
    LittleMissCabover and NewNashGuy Thank this.
  5. rollin coal
    rollin coal Road Train Member
    13,149
    26,229
    Mar 29, 2008
    TN
    Here's how I define it. When I ask a broker what his rate is what he's telling me is based off nothing more than loaded miles. Therefore a rate is what it pays per loaded mile only, the gross all in revenue paid the carrier, empty miles do not apply.
    What someone averages is a different animal. That includes every deadhead mile and also has any percentage taken off the top if they are leased, to get a true to the truck average. Anytime I toss around averages those are to the truck also including every empty mile driven and at my 89% a true spot on what the truck generated for me.
    What I or anyone averages really has no bearing on I or anyone else's rates. Deadhead skews the average and can be all over the place. Not to mention us leased drivers getting a percentage of the rate.
    If that is ever not clear then ask the poster.
    LittleMissCabover Thanks this.
  6. LittleMissCabover
    125
    83
    Sep 6, 2011
    kansas
    to rollin coal: Am I understanding this correctly, that the 89% that you stated, to be loaded miles? If so, what would you consider a percentage of empty miles driven to be average, or more to the point, acceptable? If I understood wrongly, please correct me with what you meant.
  7. rollin coal
    13,149
    26,229
    Mar 29, 2008
    TN
    No that's not anything to do with deadhead. I'm leased to F2F and they get a cut of every load. I get 89% of the gross rate and they get the other 11%. Load pays $1,000 my take is $890.
    When I get back to work next week I'll post here again why trying to limit your deadhead is a very bad idea and will have you working at lower rates.
  8. Davidlee
    Davidlee Medium Load Member
    419
    156
    Aug 31, 2012
    Some of those higher rates are flatbed rate. I think lumpers are more common to Reefer than dry van.
  9. A21CAV
    A21CAV Road Train Member
    1,848
    2,156
    Oct 4, 2011
    Laredo, TX
    On dry van grocery loads always expect lumper costs. On mixed merchandise grocery loads expect to do a 10 reset at the dock. Well, almost...
    Speaking of lumpers why does the Walmart DC in Cheyenne, WY charge a $50 lumper for drop loads?
    Speaking more about lumpers the ONLY good thing about the FJ in Dallas is the no lumpers allowed sign.
    I'm leased on to a company and with their loads I'm paid a slightly reduced rate for empty miles with no fuel surcharge rebate and a banded mileage rate plus FSC for loaded. On load board freight I'm paid lump sum for empty and loaded miles with FSC with lumper, multiple stop, detention, tolls etc paid as extras.
    Frank
  10. Knucklehead619
    Knucklehead619 Medium Load Member
    537
    591
    Mar 11, 2014
    Flyover Country
    Almost any WM DC will charge an unload fee of $50. Live unload or drop someone still has to unload that trailer. I get these all the time and generally the shipper has prepaid so I just sign the WM receipt and turn it in with the trip paperwork. Easy enough.
  11. razor1983
    razor1983 Medium Load Member
    500
    509
    Jan 17, 2011
    You should always include deadhead miles when negotiating a rate, at least I do. And so the more deadhead miles the better, since then you are paid to haul air. Case in point last week I deadheaded out Minneapolis to Greenbay 300 miles to pick up a load going to Cincinnati all in rate was 2.35 a mile.
    Where it gets tricky is if you try to bounce out of a bad area without a pre-booked load, you may end up having to eat that expense of deadhead.
