O/o fixing up your ride??
Discussion in 'Ask An Owner Operator' started by Trucker327, Jun 23, 2019.
  1. Trucker327
    Trucker327 Light Load Member
    176
    20
    Dec 24, 2017
    I have a question...how do you take off the back lights above the catwalk?
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Take the three screws out and they will come right off.
  4. Trucker327
    176
    20
    Dec 24, 2017
    Ok..and also how do you take out a stereo deck..in a frieghtliner?
    Rideandrepair Thanks this.
  5. HillbillyDeluxeTruck
    5,941
    30,369
    Mar 3, 2013
    San Antone
    Chainsaw, hammer, sawzall will all work.
    Or like every other head unit, which usually require the removal keys that slide down the side of the deck. Or in a pinch a couple butter knifes will work.
  6. Fairweather
    Fairweather Light Load Member
    94
    202
    May 8, 2018
    Most trucks have what is called a Single DIN deck. The vast majority of those manufactured recently use two flat "keys" inserted on both sides of the receiver. The keys hold down the spring locks that pin the deck into the mounting bracket. Push the keys in and leave them there. Then, the deck should slide right out. s-l400.jpg
  7. Trucker327
    176
    20
    Dec 24, 2017
    Ok...sawed the radio deck...I put in the radio...connected the main wires..ground...red...yellow and orange...but the stereo wont turn on...what am i doing wrong??
  8. Fairweather
    94
    202
    May 8, 2018
  9. Trucker327
    176
    20
    Dec 24, 2017
    Yup..off and on...im getting nothing..
  10. Fairweather
    94
    202
    May 8, 2018
    I installed a deck in a Cascadia awhile back. I may be misremembering but it seems like the wires were miscolor coded in some way. Can't remember exactly but, if you have a multimeter, you may want to check voltage to see which wires are hot and which are ground.
  11. Rideandrepair
    17,447
    56,613
    Aug 8, 2015
