o6 cummins ISX oil filler tube leaking.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bad Monkey, Nov 12, 2014.
  1. Bad Monkey
    Bad Monkey Medium Load Member
    576
    367
    Jul 18, 2012
    Goshen, IN
    Hi guys, I recently had my head gasket replaced and soon after seen it was leaking about 1 gal every week or two. It won't leak when idleing. looking at the front it looks like its coming out of the bottom part of the tube where it screws into the front case. I can move the top part up and down pretty easily. If I take off the hold down bracket will it have enough thread to go around again? Can I put some rtv on it. I have to fix before I get home so I can pass the company inspection. Thanks guys, Rob.
  3. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    kenworth replaced the seals 3 times. i did the rtv. peterbilt ended up replacing. cracked at the bottom. wasn't a big crack but enough to SLIGHTLY leak.
  4. Bad Monkey
    576
    367
    Jul 18, 2012
    Goshen, IN
    Thanks, snowwy. I guess ill just have to take it off to see.
  5. stadingfarms
    stadingfarms Bobtail Member
    38
    7
    May 5, 2014
    il
    I've had them crack on company units the tube and the part the spins into the front cover not too hard to change. So I'd check that before just buying the gaskets
    Bad Monkey Thanks this.
