Occasional driveline clunk 94 mack
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BronsonA14, Oct 6, 2025 at 8:06 PM.
  1. BronsonA14
    BronsonA14 Bobtail Member
    18
    6
    Oct 30, 2024
    Just had an occasional clunk start in my 94 Mack with Eaton super 10 and Mack rears. When it does it it’s a consistent clunk every second or so and only does it under partial throttle. Goes away at no throttle or full power. Not sure what can be checked externally but don’t see bolts in flywheel housing missing or loose and throw out bearing, input shaft etc. appear fine what I can see. It really sounds like something in transmission area causing the sound but won’t rule out anything in driveshaft or rear ends. All u joints and driveline bearings feel fine. One thing I wondered is I recently had 4 new drive tires out on rear axle and front drive axle has used tires. Could there be enough of a height difference there to cause an issue? I also drained a little oil out of transmission and didn’t see any filings or chunks of metal. Anything else that could be checked?
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,498
    6,547
    Aug 26, 2014
    Is your power divider air shifted or that Mack automatic deal?
