odd heat issues
Discussion in 'Peterbilt Forum' started by damutt, Jan 13, 2015.
  1. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    i have a company issued 2013 387. bunk heat works great, trun it down, then a hours later turn it back to heat and its cold? truck has been runnint conitsuly for 12+ hours. any ideas
  3. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Most bunk heaters are programmed to only run for so many hours then shut off like the Espar and Airtronic. Instead of turning the heat up try turning it off then back on again.
    These units can be programmed to turn off at 6, 8, 10, 12 hours or stay on all the time.
  4. damutt
    1,126
    370
    May 6, 2013
    sorry i should have state running the main motor(isx) webasto is having issues as well(tied into APU)
  5. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Been thinking and can't think of anything obvious other then the electric valve that controls the bunk heat.
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    If the heater hoses going into the bunk are hot, I'd check the door flapper for hot/cold. I don't think you have a valve that shuts coolant flow off. They are pressure sensitive and we've had a few that were sticky and would get hung up sometimes. If it's too hard to move the flap, it stops trying. I can't remember if it set a code or not though. I'm thinking that it did set a code, but not a driver warning, we had to hook up ESA to find the code.
    Skate-Board Thanks this.
  7. jwwrightjr
    jwwrightjr Bobtail Member
    Sometimes on some trucks if the engine is at idle it dosent flow enough water to the bunk system. Try bumping the idle up a couple of hundred RPM.
