oem cat or ipd parts for a 4mg cat rebuild?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by bjrc, Sep 14, 2018.
  1. AkNK8489
    AkNK8489 Bobtail Member
    23
    8
    Jul 3, 2019
    Brand new head, no core needed, block took it to machine shop that cat sent me to, every single thing in the engine is brand new except air compressors
  3. bad-luck
    bad-luck Road Train Member
    3,320
    6,102
    Nov 16, 2013
    Baltimore, Maryland
    Wow! I am sorry that's unbelievable
  4. AkNK8489
    23
    8
    Jul 3, 2019
    I did out of frame rebuild even sand blasted the engine and powder coated the engine
  5. bad-luck
    3,320
    6,102
    Nov 16, 2013
    Baltimore, Maryland
    When you try to do everything right, go all out. This is the close to the worst news you can get
  6. Kw Owners Club
    Kw Owners Club Bobtail Member
    42
    22
    Jan 1, 2019
    The only people that have had success with inframe kits I've heard of are IPD kits,and I've heard of 2 people using interstate mcbee kits and had success,but the gaskets are junk.But I also have a supplier that quit selling mcbee kits for cat cus head gasket problems,they'll only sell them to 430hp engines nothing higher.
  7. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Whichever way you end up going put a new head on it not a Cat reman, they're like playing Russian roulette. I know a guy got about 150k on a rebuild and had to redo it again because the reman head cracked.
  8. wore out
    wore out Numbered Classic
    16,258
    197,129
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    You keep it clean and do good work nothing wrong with PAI. Thing is you can see/feel cheap parts in your hands. They make micrometers and plastigauge for a reason. You do half ### work you get a half ### job. But hey it's easier to say bad parts lmmfao.
    kranky1 and Kw Owners Club Thank this.
  9. PSM379
    PSM379 Heavy Load Member
    908
    3,691
    Apr 19, 2019
    Guess I will add to this thread, thinking of going the IPD route on a 400 HP 7FB, was told by a friend to check out head made by APC basically OEM spec from what I’m reading haven’t called them yet to see if they offer a 3406B head as there website just states 3400 series. Any solid advice on any of this? If I went cat parts I’d have to peice it all together it seems. How about reusing Connecting rods? Anyone go this route can give some real advice and opinions? Thanks in advance
  10. wore out
    16,258
    197,129
    Jun 5, 2013
    APC makes the only aftermarket head I would consider. Get a hold of Robert Calixtro he can fix you up. Right at 3500.00 usually takes 2 days or so to get it.
    As far as reusing the rods you need to inspect them really well on the crank end. Usually they are fine to reuse though I put new rod bolts in every time.
    PSM379 Thanks this.
  11. PSM379
    908
    3,691
    Apr 19, 2019
    Thanks for the input
