oil analysis
Discussion in 'Ask An Owner Operator' started by The Great 1, Feb 24, 2014.
  1. The Great 1
    The Great 1 Light Load Member
    55
    12
    Mar 4, 2012
    tennessee
    Whats the best way to go about getting an oil analysis.? I have a c15 cat. Do all analysis go the same place? Just curious about this I should have been doing this for last couple years. Getting high miles and just want to check things out.
    Thanks
  3. Edgar2191
    Edgar2191 Light Load Member
    178
    33
    Apr 9, 2013
  4. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    I do one at every service. Problems can start up in only 20,000 miles and its good to see whats happening as soon as possible. I use horizon which comes pre packaged with the OPS eco pure unit I have. Stay away from speedco samples since they are not as accurate. The important thing is to watcht he trends. Compare samples after every service and see if things are getting better or worse. This will show you developing problems before they get out of hand.
    The Great 1 and gpsman Thank this.
  5. rollin coal
    rollin coal Road Train Member
    13,088
    25,923
    Mar 29, 2008
    TN
    Your local CAT house sells sample kits for $12. They do their oil analysis in house. The price includes a pre-paid USPS envelope to drop your sample in the mailbox after you take it. Do it every oil change it's really cheap insurance. Also good to have documented with CAT when you decide to sell.
    gpsman and The Great 1 Thank this.
  6. hawkjr
    hawkjr Road Train Member
    1,652
    638
    Feb 28, 2010
    Virginia
    How inaccurate are SpeedCo's analysis??
  7. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    somebody told somebody that heard it at the TS
    that Speedco only uses testers that failed chemistry
    MJ1657 Thanks this.
  8. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    kevin Rutherford couldn't have said it better. I do think kevin is a bit biased somewhat cause eco pure is a major sponsor, not that that's bad, but just a natural occurrence, you don't bite the hand that's feeds you
  9. mtoo
    mtoo Road Train Member
    1,928
    4,427
    Jan 15, 2011
    Retired on bended knee
    I have used Polaris Labs for many years. Don't have an OPS, I have FS2500. I have also used Speedco 6 or 7 times. I never had a false high on Speedco as compared to Polaris. I don't think Speedco is anywhere near as accurate as Polaris, but will give good ballpark numbers.
    For those that don't change your own oil, but want to use a quality lab like Polaris, Polaris sells a variety of sample valves you can install. Then you can pull a sample any time you want.
    Any time you have have a hit on an oil sample, you want to take another sample and send it in. Don't spend a bunch of money because of one sample. Verify the results, doesn't matter it your using Speedco, Polaris, Cat or any lab. Get another sample to verify the results.
  10. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,423
    Mar 23, 2012
    Good to know that USPS is behind the shipping on this; Drivers can expect to see the results between summer solstice and winter equinox.
  11. LBZ
    LBZ Road Train Member
    1,771
    1,266
    Oct 22, 2008
    Road to Nowhere
    Always have my results within 72 hours from mailing it(granted, not counting weekends as the oil lab is closed). Mine are through CAT as well & go over to IA.
