Oil change in rear drive axles/diff
Discussion in 'Trucks [ Eighteen Wheelers ]' started by grainhauler, Jul 5, 2012.
  1. grainhauler
    grainhauler Bobtail Member
    28
    Changing the oil in my 379 petes axles/diffs. When I drained the oil it was above the plug in the middle of the diff cover. About 1.5L above on the back axle and 2.5L above on the front axle. Is this normal? Always thought you filled to the plug and that was good. Do you fill the rest through the breather? According to the oil samples the back is 14L and front is 16L capacity. While I am changing the oil in these is there any other oil I should be changing in the back?
  3. Ezrider_48501
    3,845
    5,133
    Apr 2, 2011
    bismarck, nd
  4. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    Yep to the bottom of the fill plug, if you try and have more than that it just runs out. Never ever try to ad more by the breather tube, you will be placing excessive pressures in the rear axle housing. I know a guy who did fill er up by the breather, that was a mess.
  5. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,045
    May 13, 2011
    Middle Tennessee
    Is your truck parked on level ground?
  6. grainhauler
    28
    Yes its in the shop on level ground.
  7. alaga
    alaga Light Load Member
    195
    62
    Jan 9, 2012
    Fayetteville, GA
    Fluid you're draining doesn't look like dirty/chocolate milk, does it?
    My Mack rear was getting water in it every time I drove in the rain and then blew a wheel seal; I didn't know enough about rears to know and the Mack dealer had to fix this issue 4 times until they (finally!) figured out the forward rear needed to be re-sealed. I know your truck doesn't have Mack rears, but thought I would mention water intrusion but that still probably wouldn't account for the extra fluid.
    You been fording rivers lately? Ice-road trucking on thin ice?
    I can't say, but does the power divider have a separate reservoir for lube?
  8. grainhauler
    28
    Filled to the plugs. I am starting to wonder if the previous owner had over filled them. Came out blackish and smelled like used gear oil. Was time for a change. Could only find the 2 drains on the diffs so am going to guess everything is on the same reservoir.
  9. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    Just told ya on agtalk. :biggrin_25522:
