Oil coming out of breather on rear differential on 579
Discussion in 'Peterbilt Forum' started by Edjahman, Jul 25, 2018.
  1. Edjahman
    Edjahman Medium Load Member
    648
    444
    Apr 2, 2013
    I have a 579 thats 2.5 years old.
    This summer has been super hot lately..110-112 degrees lately.
    I've been getting oil come out of the breather tube on the rear differential pulling over the grapevine.
    It's not a huge amount of oil but it's making me mess and it's annoying.
    I took the plug out in the morning before I took off and it was coming out and it appears to be over full.
    This just started this summer so I thought it was weird.
    It's synthetic oil and it appeared and smelled normal. It has 300k on it.
    Any suggestions guys?
    Thank you!
  3. Espressolane
    17,056
    103,159
    Change the oil. 300K it’s time
    The vent is doing its job. When was it serviced last?
    It is possible that it was checked and some was added, this may have over filled a bit.
  4. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    its a vent hose. squeeze the hose. make sure its not sticking.
  5. mc8541ss
    mc8541ss Road Train Member
    1,467
    2,015
    Sep 22, 2007
    Lower Alabama
    I would also change it. I know some that say the synthetic is good for 500k. But I change mine every couple of years. About 240k-250k. ( I know, I’m working way to much)
  6. MM71
    MM71 Heavy Load Member
    758
    987
    Jun 28, 2008
    AZ
    Change the oil, grab a sample while you're at it to make sure there are not any excessive wear metals. High temps can mean failing bearings.
    mhyn Thanks this.
  7. Edjahman
    648
    444
    Apr 2, 2013
    OK I'll check all of those things.
    Thanks everyone!
  8. Edjahman
    648
    444
    Apr 2, 2013
    It got up to 300 degrees today....the rear differential...going over Donner Summit and that was really disturbing. I I was maxed out at 80k.
    I've had some of my fellow drivers say it's good to 300 and even Peterbilt said the same thing.
    When I'm not in the mountains it's fine.
    I have to get the tractor serviced really soon so hopefully it'll get figured out.
    I'll only have this tractor for another 8 months and then I'm trading it in for a new one. I'd like to not blow a rear between now and then.
    It seemed like it stopped blowing oil out of the breather tube though. When I pulled the plug the other day, it seemed over full.
    Thank you for your replies everyone!
  9. MM71
    758
    987
    Jun 28, 2008
    AZ
    Seriously ... change the oil. That will probably drop your temps by 20%
    Grab a oil sample. See if you have tons of wear metals, I'm guessing with the temps you are seeing ... you may have a bearing failing.
    Edjahman Thanks this.
  10. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    If it's never done it before under the same conditions, I'd pull out the drain plug if anything just to give you peace of mind...
  11. Edjahman
    648
    444
    Apr 2, 2013
    Had it looked at today. Oil is good and no metal. Apparently the rear driver was over full and it seems that the gauges are wrong.
    I'll have to get one of those fancy IR heat guns.
    Bizzare stuff.
    They are under warranty for 500K miles too so that helps I suppose.
    Thanks guys. The saga continues!
    MM71 Thanks this.
