Oil Consumption in Cummins ISX
Discussion in 'Kenworth Forum' started by ChrisM586, Oct 11, 2013.
  1. ChrisM586
    ChrisM586 Bobtail Member
    Oct 11, 2013
    We have a Kenworth T-700 with the Cummins ISX engine in it. We are currently going through a gallon of oil every 2000 miles or less. Cummins says that this is normal. In my Freightliner with the Series 60 I have 665,000 miles on it and have never added a gallon between changes (25,000 miles) and don't understand the consumption issue. BTW...engine only has 170,000 miles on it. Please help with some advice/answers.
    dc730 Thanks this.
  3. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    My ISX doesn't use the first gallon until 12k miles.
    BTW, this same question has been covered in the general maintenance forum.
  4. manasteel
    manasteel Light Load Member
    124
    32
    Sep 10, 2012
    yes for this engine it has become the norm. you need to get an oil consumption sheet and document oil consumption. cummins states 1 quart to 500 miles is to much. the problem is carbon packing on the piston above the top ring. the carbon packs in between the piston and liner and is so abrasive it polishes the liner out. cummins has a piston that is a little smaller that helps the issue.... what do they mean by helps? does that mean it takes a little longer to pack full of carbon? Ive seen engines with 120,000 need rebuilt due to carbon packing. this is a widely known issue and getting help from your local dealer shouldnt be a problem. if your warranty is up see if you can get policy to help cover the cost
  5. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    YIKES! Really? Is there anything they can put in fuel to rid piston of carbon? That is not good at 120000 Miles!
  6. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    i'll use 3 quarts between 15k mile oil changes.
    about 1 quart if i mainly cruise in the lower rpm's. higher rpms for the hills.
    600k miles.
  7. Casual Trucker
    Casual Trucker Medium Load Member
    495
    326
    Sep 7, 2012
    Check the Blow by when idling see if your blow by is dripping oil or if your truck has excessive Smoking when shifting gears
  8. Rawze
    Rawze Medium Load Member
    328
    818
    Jun 29, 2013
    inmytruck
    Does your truck take DEF fluid?...If so, then its a common problem, but should be fully covered under warranty. Take it to a cummins shop instead of the dealer. There are some updates to the engine to fix it, but you will need new piston liners as well.
    deming807 Thanks this.
  9. JW Trucking
    JW Trucking Bobtail Member
    34
    Mar 14, 2011
    MT
    Same problem with our 2013 were is the link to the thread that this is a known problem or is there a service paper from cummins about this issue?? Right now we are at 2-Gal every 10,000.00 Gal
  10. deming807
    deming807 Medium Load Member
    359
    116
    Jul 31, 2013
    Summit IL
    Rawze, could you please explain more detailed? Thank you.
  11. Rawze
    328
    818
    Jun 29, 2013
    inmytruck
    Its all hear-say unfortunately,...My O/o friend who does all his own work to his truck told this to me. If you have a CM2250 engine (he does) that takes DEF fluid, there is a warranty fix and update for it. His truck did this. He is polish, so its difficult to say what they did exactly, he doesn't know some English words, but he ended up getting liners, a new fuel pump, and more I think. This is all I know about it. His truck was sucking oil a lot, and they blamed it on clogged crank case filters, etc,...etc,...etc,...Until he bugged them enough that they looked deeper into the problem, where he told me there was an update for the engine for it. His engine no longer has those problems, I do know this. Maybe I try to call and ask him about it again.
