Oil in Coolant
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Grouch, Apr 15, 2017.
  1. Grouch
    Grouch Road Train Member
    2,079
    4,243
    Feb 3, 2009
    Between here and eternity
    Last nite, I was getting ready to go out, cranked the truck, it ran for a few seconds and shut down. I checked the coolant reservoir, dry and when I shined the flashlight down in it, I saw "gunk". Called our mechanic, he came out, checked it and declared that it was a blown head gasket. Now, my question, if oil was getting into the coolant, no doubt about that, why or how did the reservoir not overflow, what happened to the coolant?? No coolant in the oil, so where did the coolant go?? I am just a dumb truck driver, I realize this fact, but it doesn't make sense,
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    If it is in fact a head gasket, then your coolant most likely burned out your exhaust. Did you drain the oil, or just look at the dip stick? If your oil cooler failed, it would push oil into the coolant, but when you shut it off, coolant pressure is higher and coolant can push into the oil. You would not see it on the dipstick if that happened over night and you did not run it long enough it to churn it. The coolant would be at the bottom of the pan.
    AModelCat, xsetra, BoxCarKidd and 3 others Thank this.
  4. spyder7723
    spyder7723 Road Train Member
    15,467
    25,010
    Mar 31, 2013
    sarasota, fl
    If you got the head off to change a head gasket you really need to consider going ahead and doing an inframe. 90% of the labor in inframing an engine is getting the head off.
    To determine if coolant is in the oil the easiest way i have found is let it sit a few hours and crack the drain plug. Oil floats on coolant, so the coolant will drop to the bottom of the pan. When you crack it open, the coolant will come out first. I limited a truck from wisconsin home to Florida by doing this. Ran 5 hours, leet it sit a while, drained the coolant out of the pan, topped off the reservoir and ran 5 more hours. Pain in the butt but got it home so i could rebuild it at cost vs 12 grand at some detroit shop.
  5. Grouch
    2,079
    4,243
    Feb 3, 2009
    Appreciate the replies. Very good advice and the coolant i n the bottom of the pan. I only pulled the dipstick. The mechanic is really not an engine man, he does pretty good with what he has to work with, but they will send this truck to our home office to be repaired. We do have two super engine men there. Thanks again.
  6. WildK100c
    WildK100c Bobtail Member
    What kind of engine?
    What does the oil look Like?
    Up till the point of coolant loss was there a decrease in power?
  7. WildK100c
    One more thing may have a pin hole just starting in oil cooler or water pump turbo
  8. Grouch
    2,079
    4,243
    Feb 3, 2009
    Detroit ----Oil looks like black oil---no loss in power
    A small round hole was found on the left side of engine block right about where the starter is at. The small round hole had threads in it and the mechanic inserted a bolt that would fit and screwed it in. Oil is still in the coolant, I was told to "run it". The oil level is staying normal, the coolant level is also staying normal. I have put over 1500 miles on the engine since all this took place. Have not added oil or coolant. Everything is normal as far as running goes.
  9. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    If there's oil in the COOLANT not the other way around I'd lean towards an oil cooler long before a head gasket just my .02 I've had the problem not once but twice in 2 years.
    Both times it was an oil cooler (I have 2 1 on the trans 1 on the motor one went then the other). Usually with a head gasket it'll either push water out the overflow when it's topped off put water back into the oil or blow water out the stack (combo of all 3 in some cases).
    It doesn't take long to gum up the tank either little oil makes a large mess both on the ground and in the resiovouir. Cascade complete packs work wonders after draining the system fill with water run it up to temp then flush and repeat until the water runs clear.
    Grouch Thanks this.
