Hello, I've got a minor oil leak in the back of the engine on passenger side, but not sure where is it coming from. Went to the shop, they replaced egr heater and told me that that it was it. 700 miles later fresh oil stain reappeared at the same spot. Maybe any of you ran into the same issue or might have an idea what may be the cause?
Thank you
Oil leak Cummins isx KW T660
Discussion in 'Kenworth Forum' started by jbtdriver, Feb 26, 2018.
Another pic
Flywheel housing gasket. Need to pull transmission, clutch, etc to get to it. Let it seep til clutch time!
Valve cover gasket on the back
2 cam covers on the back
Flywheel cover gasketjbtdriver Thanks this. -
got the same answer from the shop -
How bad can a flywheel housing gasket leak?
Bad. Most people think it is the rear main crank seal. It is going to be flywheel housing gasket. Worst job in shop to do!! It is how I punish my guys that are getting on my nerves. I do bonus them for this job. It sucks.
I had one in today that would drip when idling. By the looks of the underside, its been happening for a long time
bell housing
QUALITYTRUCK, spsauerland and pushbroom Thank this.
